Contemporary Tropical Setup
Discussion in 'The Lounge' started by Ken80s, Feb 14, 2018.
  1. Ken80s
    Ken80s Well-Known Member
    Malaysia
    I would like to share with you my homemade wood rack for my music room. This is how it turns out to be from raw materials to finished good. I always like the warmth tropical taste and now I find a way to blend them into my music hobby.
  2. autoreverser
    well done, nice job, congrats - makes it look classy and seems to workout useful as well :thumbup:
    Ken80s likes this.
    Nice rack Ken80s, I'm curious what the DVD player is for, I'm guessing there's a TV up on the wall.
    Ken80s likes this.
  4. Ken80s
    Malaysia
    I used to play CD using the DVD player. Basically there are 3 music sources rendered, the vinyl turntable, CD and mp3 via FM transmission.
    I'm not familiar with the JVC Unit but it looks like a CD Player, so I thought you might be using the DVD player for another format, for a while some DVD players had MP3 capability and I thought it might be used for that.
  6. Ken80s
    Malaysia
    This experiment suggested best sound quality for mp3. Since then I have stick on to this!
    I love cool little gear but I'm confused. The little unit play "HUMAN" is broadcasting on 87.5? You have two different boxes, and what's the gold thing on top of the little black player, it looks like a memory stick.
  8. Ken80s
    Malaysia
    I have several units of these car mp3 player for different boomboxes. Modify them for home use. It supports SD card and memory stick inputs and also auxiliary.
    These are cool for cassette players or testing a player with broken belts.
    Ken80s likes this.
  10. Deliverance
    Deliverance Active Member
    United Kingdom.
    Some quality there Ken .
  11. PHILIP[
    PHILIP[ Member
    Birkenhead
    HOW does the ION cassette adaptor bluetooth test for broken belts ? Can you use it in an ordinary cassette player personal cassette where bluetooth is available so you could use your cassette player in the car if you do not have a cassette player?
  12. PHILIP[
    PHILIP[ Member
    Birkenhead
    On the picture of the stool should you not counter sink the screws on top so you do not risk snagging your clothes or you bum if you are that way inclined but nice and simple and cheap idea for display
    The Ion will work if the belt is broken, feeding a signal through the unit to test the audio path. It probably is more helpful in units without a radio like walkmans and field recorders.
  14. PHILIP[
    PHILIP[ Member
    Birkenhead
    I am not technical but willing to learn . How do you follow the signal and what does it prove ?
    I just bought a field recorder that has broken belts, there's no radio so I don't have a way to test the sound (or power) to make sure there's not a bigger issue. By using the Bluetooth Cassette Tape I can broadcast a signal to the tape inside of the deck. I should then get either sound through the built in speaker or through headphone outputs. The reels on the Ion Tape do not need to turn to work so even though the belts might be broken I'll still get sound.
    The Ion is great if you use your phone for music or the radio and want to broadcast to your Walkman or boombox.
  16. Jorge
    Great tip, Thanks!!!
    Q: when I use cassette adapter for line-out (from iPod or Discman), after 20-30 min of play something (adapter or cassette head or both) is over-saturated and music gets distorted, five more min and there is nothing but noise coming from the speakers. Same thing with Ion?
    Are you using the cassette that has the mini-plug on it? If the internal Ion Batteries start going bad they don't sound very good, I had a cheaper version and it had a very short life. Ion seems to be better quality brand but I don't know how long the batteries last. I don't take my boxes out as much as I used to, I have an Ion JobRocker now that lights up the ice-rink. My boxes are cool looking but no where near as loud.
  18. Jorge
    no, I was using something as simple as this, no batteries:
    no over-saturation with Ion, then I will try one!
    You do have to hit play so if there's any broken bits you'll hear them turning around.
