Need a DD33 and a DD30 owner Please
Discussion in 'Tech talk' started by wm_dan, Nov 23, 2017.
  1. wm_dan
    wm_dan Member
    UK Yorkshire
    Hi Guys
    Please can anyone tell me do the DD30 and DD33 have the same headphone output power?
    My WM-DD3 has not a very powerful output amp and can only drive smaller headphones
    But my DD33 can drive bigger ones just fine.
    I have an opportunity to buy a DD30 but I don't want another walkman with a weak internal headphone amplifier
    Thanks
  2. walkman archive
    I have both of them and I bet they have the same output power Or at least very close to each other
  3. buzbox
    buzbox Active Member
    Australia
    Is the DD-30 one you recently purchased? If so then there is always a chance a previous owner has tried to play around with the level adjustment pots.
  4. A O
    A O Active Member
    The English Riviera
    They were techincally identical
  5. enryfox
    enryfox Active Member
    close to Milan (Italy)
    Output specification is identical, 10 + 10 mW with 32 ohm load. The output amp IC is the same (TA7688F) configured as unity gain amplifier (it increases the current output to manage low impedance load) but the megabass IC is different and that is responsible for voltage amplification. But I guess that voltage output is the same and anyway with volume set to 7 you already reach the maximum output allowed by the DC bias of the output amplifier.
  6. wm_dan
    wm_dan Member
    UK Yorkshire
    Cheers for reply guys
    Also my wm-dd3 had a ground issue which sounded like distortion high up in the volume range
    I think it's ok now
