I know.... New Cases, Stickers and of course, Marians truly awesome Gears... Well, I have something new up my sleeve.. So, as many of you know, I own a visual effects studio and we provide a lot of laser scanning for Marvel and Disney etc. I decided to scan the Door latch for the DD models. This has always been a weak design point. They all seem to go, and with no spares available, you either have to trawl ebay or resort to a rubber band. The plan is to take the scan and use that as ref to design a new version with more "bite". I will then print a limited run of these using our super awesome FormLabs SLA printer in Tough engineering resin. These will be UV cured for three days for strength and then primed and spray painted. I will probably sell them in packs of three, to keep you going for a good few years So here is the scanning: Here is the Data from that scan: So if you suffer from a loose door, help is on the way!!!!! I will keep you abreast of the modelling phase and first test prints
New modern times without Charlie ... This is great! Of course interested! Note me at your order book please!
Not quite sure I get the modern times / Charlie ref.... but yes, watch this space. Quite an easy job, assuming all the DD units (not the DD9) use the same part...
Unfortunately I do not have any extra but if you don't get appropriate answer I might open a D3 to show it to you
Great news indeed! My one and only DD already got a new gear from @mihokm Door latch is also broken, its good to know that help is coming Thanks!!!
Hi guys! I just now registered SPECIFICALLY for this! If this does indeed become a reality, I'm in for 2 (one for my daughters DD3, and one for my DD30)! Will the resin material hold up better than the plastic has? Best, Vanya
