Each time I have replied to someone else's post on the new site it seems to have gone a bit wrong and ended up with my text after theirs in the same block. Probably finger trouble on my part but the technique is obviously different to what you had to do on Hoop-La. Could someone explain how this is supposed to be done; maybe by replying to this post.
If you click the small "reply" button you quote that person in your reply and have to press enter once to start a new line seperate to their quote. Type here If you just type a message in the reply box at the bottom and click "post reply" you just reply in the thread with no quote.
Thanks. The most important bit, which is where I was going wrong, is to not delete the [/QUOTE] if deleting non relevant text from the quote.
