re-lube cassette tape
Discussion in 'Cassettes' started by Reflex85, May 30, 2017.
  1. Reflex85
    Reflex85 Member
    Is there a way to re-lube the tape? I suspect that its going to be the only way I can get rid of the tape squealing on my Dokken cassette. Its definitely not the machine, its the cassette.
    I was thinking that I could maybe put a little coconut oil on the pinch roller, let it seep in and just let it lube the tape as it passed through. Probably wouldn't be bad for the roller since it need some lube too.
    what do you guys think?
  2. Helaba
    Helaba Active Member
    Belgium
    I do not think Thats a clever solution!
  3. TooCooL4
    Change the sheets that sandwich the tape it may help.
    Command8 and cmarti like this.
  4. cmarti
    cmarti New Member
    Orlando, FL
    Changing the housing will take care of that
  5. Boodokhan
    When i get this issue a simple solution always help me
    try to tap the cassette on a hard surface a few times to loosen the tape
  6. Helaba
    Belgium
    Thats what i call " tap dancing?":)
