Sony WM-EX50 very low volume
Discussion in 'Tech talk' started by Ant1vl, Feb 1, 2018.
  1. Ant1vl
    Ant1vl New Member
    Netherlands
    I've searched the internet, but found nothing about following problem. Hope someone has experienced it and maybe has a solution.
    I have 2 WM-EX50's. They both suffer the same problem: very low output volume through headphone output. I connected different headphones, but sound is hardly audible. Probably some component in the signal path has degraded over time i guess.
    I've downloaded the servicemanual. However i don't know which part could be malfunctioning or even if it is replaceble at all.
    Does anybody here have experience with similar problem? I have several walkman, but this model is the only one with this problem.
  2. bub
    bub Active Member
    Singapore
    CDV likes this.
  3. Jorge
    My buddy Kaosun of kaosuncd.com says the same thing as @bub : recap first, start combing for trouble later!! And, unlike myself, Kaosun knows what he is doing allthetime!
    So, if its low at both channels its a busted bypass electrolytic, if not... But start with a full recap, that is a given!
  4. Ant1vl
    Ant1vl New Member
    Netherlands
    Thank you both mucho, i will try to do a recap :)
  5. xequtor
    xequtor New Member
    erth
    did you recap your EX50? if yes which caps did you change?
  6. Ant1vl
    Ant1vl New Member
    Netherlands
    Yes. I replaced all the caps and that fixed the problem. Walkman sounds very clear with good volume now.
    edchocolate and CDV like this.
