Any tips on fixing volume control on Sony F702?
Discussion in 'Tech talk' started by vincentv478, Apr 13, 2017.
  1. vincentv478
    vincentv478 Member
    est
    Hi all, I recently bought a F702 and fixed it up. I am having an issue where the volume control is really noisy and one of the channels keeps cutting out unless I place it in the perfect spot.
    Any ideas on how to fixit?
  2. Brutus442
    Brutus442 Well-Known Member
    Toronto
    Perhaps a spray of Deoxit on the pot may help. It maybe just a tad oxidized from the sounds of it.
    vincentv478 likes this.
  3. autoreverser
    Brutus442 likes this.
  4. vincentv478
    vincentv478 Member
    est
    Thanks, the pot seems sealed, do you think it will penetrate if I spray on top?
  5. Brutus442
    Toronto
    Not sure but it may help to adjust the volume while applying it. It's a very safe product to use and I've never experienced any side effects from "a light overspray".
  6. vincentv478
    vincentv478 Member
    est
  7. doublecee
    doublecee Active Member
    Earth
    Yep. Go for it.
    Make sure you work that control back and forth as soon as you have sprayed too. No need for a cassette to be loaded.
    Also listen with headphones connected. Then you can hear the improvement and ascertain if another spray or two is needed.
    Brutus442 and vincentv478 like this.
  8. vincentv478
    vincentv478 Member
    est
    Deoxit is epic. Fixed it perfectly, The needle is great, 1 drop in each hole fixed it perfect. Thank you.
  9. Brutus442
    Toronto
    Deoxit is my goto when I have sound issues. I always have a can on standby. Glad it worked!
  10. Deliverance
    Deliverance Active Member
    United Kingdom.
    Result happy days .
