Best way to digitize old cassette tapes?
Discussion in 'Tech talk' started by stereomecha99, Aug 18, 2019.
  1. stereomecha99
    stereomecha99 Active Member
    United Kingdom
    Hi all,
    How do you all go about digitizing your tapes? I have a few I'd like to backup and I'm aware I could use any simple cassette corder and aux cable + Audacity to do the job, but is there are hardware you recommend using for this task? Thanks!
  2. speedy2.0
    speedy2.0 Active Member
    London
    I’ve been using a Fostex FR2LE which records WAV to CF flash at 48/24. The only issue with this unit is the headphone amp is not the best, but listening back on a proper machine shows you how good it is. You can use any small portable, I just have one of these from years back. You could use a Zoom H4N for example, anything with pro-grade preamps will be a good deal better than a PC sound card
  3. Longman
    It depends out the sound card. You could go down a complete rabbit hole discussing those if you start looking at semi professional and professional ones.
  4. speedy2.0
    London
    Yes and no. I guess the cost of a portable is a few hundred £ and you can get a sound card for that price too. I just have this very good 2 track unit doing nothing. I would say the tape machine is more important, you don’t want to add anything to the recording that can be avoided. Otherwise the copy isn’t a true copy
  5. Tim Walters
    Tim Walters Member
    South Florida
    I will be trying to do this soon with a Pioneer CT-F1250 cassette deck to, most probably, Audacity...
    stereomecha99 likes this.
  6. stereomecha99
    United Kingdom
    Hi, I think I'm going to do the same with my Technics deck too. Will also be using it to do some recordings, just waiting on an aux cable to arrive...
  7. greg
    greg Member
    ENGLAND
    DCC outputs SPDIF. So, rip tapes via a cheap CMedia CM6206 connected to the digital out and you're away. You'll have to clean the heads, a lot.
  8. TooCooL4
    Any particular reason you want to digitise your cassettes?
    Did you get a chance to try recording?
    You made me curious so I found some MP3's at 128kbps from around 2002 that I did using a decent tape deck going straight into the desk top computer. I used to mess around a lot with converting tapes when this was new to everyone. I was using a free download of Sony Acid which helped me dial in the volume without clipping and cut the recording into individual songs. I'm listening right now to some of them and they don't sound too bad considering the equipment I was using and no sound modifications to the computer.
    I would take a few different tape decks, if you have them, and try the same song on all of them and look over the wave-form to see which one is giving you the best sound. I was looking for information on Audacitys Recording Capabilities and found this page that will help.
    https://manual.audacityteam.org/man/sample_workflow_for_tape_digitization.html
