RV301 1-228-598-00 RES, VAR, CARBON 10K/10K
Discussion in 'Tech talk' started by stef, Feb 14, 2021.
  1. stef
    stef Member
    milan
    hi
    do you know to buy this res var for wm2 and sony dd?
    it needs for audio volume on wm2 and sony dd
    thank you
    Hi stef,
    Unfortunately, you can't buy that volume pot. It's extremely rare, as most parts for these walkmans are nowadays. I don't know what your repair skills are, but my best bet would be repairing your existing potentiometer, if it's not completely destroyed or missing altogether.
    I have repaired a couple of potentiometers successfully, that had the PCB broken.
    Otherwise, the only option is to search on ebay for the part number or "walkman pot/potentiometer" and hope to find it one day. I just searched for it now and it doesn't return any results. Or buy a donor unit that has other problems and an intact volume pot.
  3. stef
    stef Member
    milan
    hi
    thank you yesterday i have repaired inside contact was separated to plastic part and didn't touch carbon resistance
  4. Colby J Lee
    Colby J Lee New Member
    Utah
    Just bought this exact part the rv301 from a site. Called encompass its only 10 dollars
  5. Colby J Lee
    Utah
    You can buy the exact part for 10 dollars from a site called encompass and I may be wrong but I swear ita sony part from aony
  6. Emiel
    That would be great! Was this pot perhaps more widely used, because there really is no reason to have this component still in stock to repair 40 year old small electronic devices. Can you post a picture of the part after you’ve received it?
    Encompass is Sony Parts Supplier in the USA, I've never order from them but they've been around awhile.
    https://sony.encompass.com/
  8. stuck-in-time
    Jakarta, Indonesia
    These pots are often broken because the wipers get loose from the plastic shaft. If that's the issue, they're fixable by dismantling it and reattaching the wipers.
