SOLVED: Can i make mixtapes through " mic in" instead of " line in" on a walkman?
Discussion in 'Chat Area' started by SantiOriginal, Sep 2, 2018.
  1. SantiOriginal
    SantiOriginal Active Member
    Tilburg, the Netherlands
  2. TooCooL4
    Sure you can, but you will not have very much control over what you are doing which means the end product will be mediocre.
  3. SantiOriginal
    @TooCooL4 tnx for your answer. I couldn't find any article or video on the internet about this subject that shows the difference between recording with line in and mic in from smartphone/laptop to walkman and explains the different facets and results of it.
    I'm aware that a walkman with lots of controls for recording including a line in means a high end walkman with dito pricetag. Unless you know a model that produces acceptable results with a friendly price :)
  4. TooCooL4
    I don't, does it have to be a portable?
  5. SantiOriginal
    @TooCooL4 I make my musictapes on my JVC tapedeck W201. Perfect results.
    I am looking for a handy portable recordable one as seen in the link above so i can record a tape and share immediatly when i'm not around my house.
  6. SantiOriginal
    Solved!
    Well, i found a tutorial. How simple can it be! All that i needed, so thumbs up for the girl on youtube who made this video!
    Edit: and here is another video-tutorial:
  7. Longman
    Typically a Mic input will require a much lower input level than a Line input. Too much signal will cause distortion.
    You could get around that by keeping the volume on the computer very low. If that isn't an option, e,g when recording from something like a CD player you need an attenuator.
    You could buy one
    https://www.ebay.co.uk/itm/Audio-At...hash=item3f189c779c:m:mfYyCSmniq2UZVobsz3FJtw
    Or if you know how to solder make one
    http://www.uneeda-audio.com/pads/?_ga=2.180843879.1596128292.1535911376-1803858337.1535911376
    It is only a few resistors.
    p.s. When I first got a CD player back in 1989 I was in lodgings and wanted to run in through the DIN socket on my Sony CFS45L.
    Despite the input being designated "Line In" I had to put an attenuator between the two, as without it the sound was very overdriven and distorted.
    Boodokhan likes this.
  8. SantiOriginal
    @Longman Thank you so much! Exactly what i was looking for: an attenuator! there is a solution for everything! A fraction of the price of an expensive walkman. I will definitly buy one!!
    I think this is the way-workaround: Let me know!
  9. SantiOriginal
    @Longman : how can i know which dB attenuator from the link you gave should I select? And should I select electrec mic? Must I look up specifications of both Walkman and smartphone?
  10. Longman
    That is the difficult bit. An advantage of making your own attenuator is that you can easily adjust the resistor values if it is too loud or too quiet. Resistors are literally pennies each.
    SantiOriginal likes this.
  11. nickelindimer
    nickelindimer Active Member
    Chicagoland
    You certainly "hit the nail squarely on the head" there, Longman... I went through the same woes when bootlegging free full-length listening on Rhapsody to cassette, and when dubbing Gary Wright - The Dream Weaver along with select tracks from Disco collection CDs to 8-track for playback on the system at work. I won't even think about using a portable in-car unless it has a line-level output. And the same goes for any computer I may wish to pipe sound from into my home system.
  12. SantiOriginal
