Type III Recording advice
Discussion in 'Cassettes' started by flash_the_84, Aug 28, 2018.
  1. flash_the_84
    flash_the_84 Member
    Paris, France
    Hello,
    I've had this Type III tape before (a Sony FeCr) and i used to have a deck that had a Type III preset. Now i want to re-record said tape using my better recorder (a WM-D6C). What preset should I use? Normal, chrome or Metal? Any advice?
    Thanks.
  2. TooCooL4
    Since the D6C has to be internally calibrated for a cassette and if your D6C is not calibrated for this cassette, then you are unlikely to get the best recordings from it.
    flash_the_84 likes this.
  3. flash_the_84
    flash_the_84 Member
    Paris, France
    Obviously, but what would be the best setting to use to record on Type III for players that don't have Type III capability? The only Type III deck I have is a 1980 Kenwood KX-500, with not much high-end, I think the amorphous head and better electronics would help better use the sound of a Type III.
  4. TooCooL4
    I don’t know, but since Type III is a blend of Type I + II maybe use Type II. I guess you can experiment.
  5. flash_the_84
    flash_the_84 Member
    Paris, France
    Now for the result : Type II gives a very bassy sound with few treble overall, (because of EQ obviously) while Type I gave me a very sharp result.
  6. TooCooL4
    Well it sounds like you have your answer, you just need to pick the sound you like best.
  7. nickelindimer
    nickelindimer Active Member
    Chicagoland
    I have a better answer: Put the blank Type-III in a safe-deposit box, and come back to it when you need money. Those things are so rare, they might as well be made of gold.
    SeanMT likes this.
  8. TooCooL4
    Only worth money to collectors.
  9. flash_the_84
    flash_the_84 Member
    Paris, France
    It wasn't blank when I grabbed it (got it from my someone's father) but it is still in pretty good cosmetic shape. It's a late 70s FeCr by Sony that goes with the AHF/BHF/CHF range of Type I.
  10. walkman archive
    The problem with type III is that there is no single optimum bias point. There are two different points, one for each compound, so there's no way to get a really good response.
    As the D6C has no variable bias you should make a real test...
