WM-D3 Battery Door
Discussion in 'Tech talk' started by subcode, Apr 10, 2019.
  1. subcode
    subcode New Member
    Greece
    Hi!
    I cannot find a battery door for my WM-D3. I've searched ebay auctions but nothing... Is there anyone here that can 3d-print this item?
    Thanks in advance!
  2. autoreverser
    look for a DD-junker, it's the same door
    jd637 likes this.
  3. jd637
    jd637 New Member
    global
    Very helpful, thank you! I'm in the same boat. Is it only the original DD model, or do you know if other DD models use the same door too?
  4. Deb64
    Leicestershire, England
    jd637 likes this.
  5. jd637
    jd637 New Member
    global
    Perfect. Thanks. :) The 3D printed door with shipping to Germany is $22.45, which is a bit expensive for me. However, from that product listing I did find the model #'s of which Walkmans I can use for a donor door.
    DD
    DD 10
    DD 2
    DD 3
    DD 30
    DD 33
    DD 100
    DC 2
    D3
    Sports FM
  6. autoreverser
    WM2 and 5 also fit, i checked...
    DD 10 does not fit !
  7. subcode
    subcode New Member
    Greece
    Thanks for your replies guys, i think im going to find one from another model like autoreverser said...The 3d printed one will cost me 30€ delivered to Greece which is expensive and will not be the original part.
