WM-F77 problems!
Discussion in 'Tech talk' started by nakamichi, Dec 30, 2018.
  1. nakamichi
    nakamichi Member
    Sweden
    Hello!
    I changed the belts and idle tyres with my 2 WM-F77. The first one works great untill it suddenly change direction. The other works fine at one direction but sounds terrible when You change direction manually. Do anybady have a experience of these problems and maybe suggestion have to solve them
  2. Migilus Migilacuty
    Migilus Migilacuty Member
    Portland, Oregon
    have you tried re aligning the play head in the reverse direction?
  3. nakamichi
    nakamichi Member
    Sweden
    Thanks for Your advice. Luckily I found the problem on the other Walkman. It was a bad soldering joint on the transport direction switch. Now It is working like heaven, but I still have aproblem with the Walkman changing direction on the go.
  4. nakamichi
    nakamichi Member
    Sweden
    Now I have found a temporary solution for the other walkman that suddenly goes to a reverse mode. If I first let it spinn in Fw and then back in Rev mode it plays ok. I still would appreciate to find a permanent solution. Can it depend on dirt or lose parts or motor problem?
  5. Costa32
    Costa32 Member
    Oporto
    Loose Belt?
  6. nakamichi
    nakamichi Member
    Sweden
    No,its New correct one.
  7. Longman
    Does it happen with all cassettes ? After your post about rewinding I'm wondering if a badly wound or sticky cassette could be causing false triggering.
  8. nakamichi
    nakamichi Member
    Sweden
    It is triggering on both directions with any cassette.
