When turned in nothing happens can't hear AM/FM stereo and tape player doesn't work. Once it was disassembled the belt drive was broken but with the radio not working I'm sure it's more than just the belt. Any suggestions would be great.Thank you
There is no simple answer to your question. sounds like electrical issue rather than a mechanical problem. Is the battery compartment clean? sometimes the oxidized contacts in the battery compartment is the problem. Check for any loose wire that can happen during opening the walkman.
