Aiwa AD-1800: Precision Engineering and Sonic Finesse in a Vintage Cassette Deck.
Discussion in 'Cassette Decks' started by Retro Audio Museum, Nov 26, 2023.
Tags:
  1. Retro Audio Museum
    The Netherlands
    The Aiwa AD-1800, produced between 1976 and 1978 in Japan, stands as a great horizontal semi-big recorder, presenting a unique combination of features that set it apart in the realm of cassette decks. The retail price of AD-1800 in 1977 was 450 USD, so it was not cheap at all, but it did provide good performance and a lot of extras for this price.
    One standout feature is the incorporation of two noise-reduction systems—Dolby and DNL (Dynamic Noise Limiter by Philips). The collaboration of these systems, with DNL operating through a gate, attests to Aiwa's commitment to achieving optimal audio quality. This dual-system setup provides users with the flexibility to enhance signal-to-noise ratios during recording and playback, showcasing a forward-thinking approach to audio fidelity.
    The AD-1800 incorporates an SST mechanism (Solid and Stabilized Transport), featuring a substantial 10.4cm, 448g flywheel, resulting in an impressive 5090g/cm torque. This design, coupled with a Hall-element driven auto-stop, demonstrates Aiwa's dedication to precision engineering. The attention to detail extends to the reel axis, capstan finish, and 4-point head support, collectively contributing to stable and high-quality tape running.
    The technical specifications of the AD-1800 reflect a commitment to audio excellence. With a frequency response ranging from 30-18,000 Hz (depending on the tape type), a distortion factor of 0.05, and a signal-to-noise ratio of 65 dB (Dolby/DNL on, FeCr band), this cassette deck ensures a high standard of audio reproduction.
    Several design choices contributed to the AD-1800's performance. The use of a stabilized power supply for Dolby circuits, bias oscillation circuits, and amplifier circuits enhances electrical stability. A center-driven reel shaft minimizes excess friction during tape running, promoting stability. The use of a flat belt with a high-precision finish minimizes transmission loss, and the fixed pinch roller holder shaft ensures accurate parallelism for stable tape running.
    The AD-1800 doesn't compromise on user convenience. Independent bias/eq switches, mic/line mixing, tape run LED, 2-level peak LEDs, auto-zero memory, quick-cue key, and oil-damped cassette holder contribute to a user-friendly experience. The cassette deck even automatically sets bias and equalizer settings when using CrO2 tape with detection holes.
    Hyperscope, Raul, Mister X and 4 others like this.
    Those old decks are really neat, us kids just had the cheap mono piano portables, we couldn't wait to grow up and start mixing real mix tapes.
    Raul and Retro Audio Museum like this.
  3. Hyperscope
    Vancouver Canada
    Yeah that's what I had through the 80's too. From when I was 5 or 6. No music tapes, just a few audiobooks, as well as myself reading stories and recording. Always the recordings were full of tape hiss and the sound of the garbage tape recorder motor mechanism itself in the mix... like an angry growling stomach in the background trying to compete with the noise of the vicious snake hissing :laugh: I literally didn't know it was otherwise until recently. Due to total lack of information. Advertisements explained nothing. Manufactures explained nothing. Required a research project on the Internet to learn the basic from obscure sources. Quite sad really.
