Sony Walkman WM-FX999 side a right channel very quiet.
Discussion in 'Discmans, Minidisc, DCC and other players' started by rcpilot23, Apr 4, 2019.
  1. rcpilot23
    rcpilot23 Active Member
    Perth
    I have new looking Sony Walkman WM-FX999
    It plays like new thanks to a new belt from Marian. [​IMG]
    The side A plays fine but the right channel is alot quieter than left channel.
    I can hear almost mumbling sound too only on the right channel.
    Side B is perfect.
    I presume Side A and B would use the same audio circuitry on the board.
    thanks
  2. Longman
    Yes and no. All Autoreverse Walkman I have seen use a 4 track head so the signal path for side A and B will be different around the heads.
    It is also possible that there is a problem with the tape path, for example something causing the tape to not touch the head properly on just one side.
    The mumbling you hear could be a trace of Side B being played backwards.
  3. rcpilot23
    Perth
    This model has 2 separate heads for playback A and B and only 1 pinch roller in the middle.
  4. Longman
    I see what you mean
    http://www.flickriver.com/photos/saka_matra_miscellaneous/10513102074/
    according to that only four Walkmans ever used that arrangement.
    It actually makes it more likely that one head of the two heads is out of alignment.
    With a normal four track single head Walkman at least you know that the spacing between the tracks is going to be correct.
    With this one I presume there must be azimuth adjustments for each of the two heads, and you could have one direction set perfectly and the other direction way out.
  5. rcpilot23
    Perth
    thanks I will check that
