The red battery LED light on DD walkmans
Discussion in 'Tech talk' started by wm_dan, Oct 21, 2017.
  1. wm_dan
    wm_dan Member
    UK Yorkshire
    Hi guys
    I would like to change my LED to Green or Blue on my DD3
    Does anyone know the exact size and voltage required. I am away from my babies for a few days so can't check atm.
    Just wanted to order some now so they are waiting for my when I get back.
  2. wm_dan
    wm_dan Member
    UK Yorkshire
    The part number is actually in the service manual, SR506D, which is a 3mm, 2.6v 4mA LED
    I cannot find a blue one in this spec, I am not sure why, I am no LED expert
    So will have be green.
  3. Longman
    By nature blue LEDs will be a higher voltage. White LEDs are based on Blue with a phosphor on top.
    Most LED torches run on 4.5v. I do have one here that runs on 3V but it is very dim.
    Green would be less of a problem but is still a bit higher in voltage.
    ebuy05, Boodokhan and wm_dan like this.
  4. Boodokhan
    @Doctor Walkman did change led to blue to make it super DD walkman.
    He has been very quiet for awhile but i am sure he can answer this question.
