Toshiba Walkman with no sound
Discussion in 'Tech talk' started by Boodokhan, Jun 14, 2018.
Tags:
  1. Boodokhan
    [GALLERY=media, 1081]605FE99E-2E9F-4EAA-8FB9-F504FCA0BC47 by Boodokhan posted Jun 14, 2018 at 5:51 PM[/GALLERY]hello friends
    I just changed the belt on this brand new Walkman , radio works fine, sound is excellent but when I play cassette no sounds can be heard . The cassette mechanism works, play, auto reverse button, FFW and REW all work.
    Any suggestion?
    Can you record on a tape in this unit and play it in another unit?
  3. Boodokhan
    haven't tried it. I can try it this weekend.
    So what will be the problem if it records on cassette that can be played on another device?
    I just have a bad habit of snapping the little wires when I reassemble equipment, they get pinched and broken. I was just thinking that maybe the wires for the heads (if there are any) might have been pinched.
  5. Boodokhan
    thanks.
    I will open it again to make sure there is no loose wire or any problem with wires
  6. Boodokhan
    Update:
    I opened the walkman and everything looked fine.
    I recorded a few seconds on this walkman and amazingly after pushing record button everything started working.
    and still I don't know how pushing record button resolved the issue.
    Thanks to @Mister X
    stuck-in-time and Mister X like this.
  7. stuck-in-time
    Jakarta, Indonesia
    Probably it's the alignment of the rec/pb switch? Like somehow it was misaligned a bit, resting at a point between the rec & pb position, so the contacts weren't lined up. By pressing the record switch (and changing it back to play mode), the proper switch position was restored.
    Now that you mentioned it, I remembered accidentally pressing record and hearing back sound from from silent unit. Did not realize the connection back then, but this will certainly be of note in the future.
    Boodokhan likes this.
  8. Jorge
    @Mister X you sound like my personal Guru, Master Gu of kaosuncd.com: to my uneducated Q he would give an exact answer:bad cap this or that, flexboard, etc. and it is Always spot-on! Truly amazing, but thats what separates boys from The Masters! I am seriously impressed!!! :thumbsup:
    I come from the school of repair where I need to fix my own fixes several times, I honed my skills on English Cars....
