Hello Gents,
I've got a wm-fx5 (ex5 with radio) and I cleaned head, pinch rollers/capstans, all the pulleys, and put in a replacement belt and have really bad wow and flutter. I got the belts in a set from DocP, so I've tried several different sizes. the belts do have a rectangular cross section and are prone to twisting. The twists seem to cause a vibration in the belt which causes w&f. Ive tried to get all the twists out but have had little success.
I've noticed that the pulley towards the top of the player has a lip on the bottom and it seems that the belt is rubbing it. also this is a pretty thin belt (less than 1 mm) and I'm sure it is the right diameter. Maybe I need a round belt?![]()
