WM-F65 No sound
Sony WM-F65, No sound from the tape out the left side of the headphones.
Sound works fine on both sides using the radio, At first i thought it was the wires from the head, But I have solderd them on and still the same thing, Also their is no buzz or running sounds from that side. I have also replaced the head wire harness in case of a break, No luck.
Is their another wire or something missing from the headphone jack? It sounds like its not getting power to the left side, And yes i have used 2 different tapes and headphones.
Help on this would me much appreciated, So bring on the brain power!
regards
Mitch
Original Post
From what you describe it may be something like dead capacitors (left side dead, right side soon to expire) on the pre-amp side of the audio from the playback head going into the pre-amp IC. Check the audio path to see if you have them on the F65 and if so, then check them with an ESR meter and see if they are good.
Just realised you have posted the schematics up for the F65. Check capacitors C103 and C203. Also check C107/C207. If there are issues with recording look at C105/C205 as well. Although you are getting sound from the radio, it is also worth checking C121/C221, C119/C219, C116/C216 with an ESR too.
Did you replace them with brand new capacitors or are they salvaged from another walkman? Have you tested the parts for ESR and capacitance to confirm they are good?
Also with a continuity meter you should check at each point that you are getting a connection. Sony have made it very easy to trace the complete audio path on their schematic diagram
Add Reply
